Kitchen table
Old 07-15-23, 09:08 AM
E
Received 6 Upvotes on 6 Posts
Kitchen table
I have a kitchen table (pictured) that is about 20 years old and over the years it has gotten to where it could use a refinishing. My wife said she would like to sand it down and put a new finish on it. My question for something like this is how do we go about sanding it? Should I use a palm sander, a belt sander, a different type of sander, or good old fashioned elbow grease? Also, is there a particular type of sandpaper I should buy? We are just going to do the top. Thanks, Rich
Old 07-15-23, 09:38 AM
Received 800 Upvotes on 703 Posts
I'd give it a light sanding, a palm sander is ok if you don't get aggressive. Definite NO on a belt sander!
Old 07-15-23, 10:40 AM
P
Received 2,013 Upvotes on 1,805 Posts
First I would decide if you just want to refinish the top which would be easy. Or, do the whole table which is a different can of worms. Even though the legs aren't complex their round shape and detailing makes sanding very difficult. The top is easy to sand either by hand or with a palm or DA sander (I agree, NO on the belt sander). The legs however might be better chemically stripped and then just a light sanding before finishing.
Old 07-15-23, 11:38 AM
E
Thanks. It's just going to be the top mainly because the grandkids used it as a drawing board. I would guess a light sandpaper would do the trick.
Old 07-16-23, 04:58 AM
If hand sanding be sure to sand with the direction of the grain. Cross sanding can produce scratches that will show up in the finish. Normally not an issue with a palm sander.
Old 07-16-23, 03:56 PM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
Orbital sander, starting with 120 then work your way up from than!
