How can this stool seat be dealt with?
Old 02-18-24, 12:59 PM
T
This is the seat of a stool we're thinking about buying from someone but the owner kindly wanted to make us aware of this gash in the wood. The price is too good to let these two stools go and the damage is only on one of them. What can be done to deal with this? I imagine it's a choice between either filling it or leaving it and just softening/sanding it. But filling you'll never get that grain again.
Any ideas? Thank you!
Top Answer
02-18-24, 04:53 PM
CarbideTipped
CarbideTipped is offline
Received 173 Upvotes on 141 Posts
If you know any woodworkers, it's possible a piece (dutchman) could be cut out of the bottom of the seat where it isn't visible and inserted into the top. The piece could be chosen so the grain matches well. But then the seat would likely need to be refinished.
Old 02-18-24, 01:14 PM
Received 839 Upvotes on 736 Posts
That is too deep to sand out. The only way I can think of to make filler look acceptable would be to apply a faux wood finish over the filler - easier said than done.
Old 02-18-24, 01:30 PM
XSleeper's Avatar
Received 1,920 Upvotes on 1,724 Posts
Yeah, I'd probably use a wood filler, something like this.
https://www.menards.com/main/paint/i....htm?exp=false
Get it as smooth as you can, might take a couple applications... drag a razor blade across it to ensure its flat. Lightly sand, add more as needed. I'd try to stain it to match the light wood but you might find that you need to faux it yourself with some furniture markers.
Example
Once its acceptable, give the seat a couple coats of a wipe on poly.
tinpanalley voted this post useful.
Old 02-18-24, 04:47 PM
P
Received 2,180 Upvotes on 1,950 Posts
I'd leave it. Call it "patina" or "character".
Old 02-18-24, 04:53 PM
C
2john02458, tinpanalley voted this post useful.
Old 02-19-24, 04:48 AM
the_tow_guy's Avatar
Received 251 Upvotes on 203 Posts
Random thought, I might consider filling it with a clear epoxy and then sanding flush after dry.
2john02458 voted this post useful.
Old 02-19-24, 07:28 AM
P
Received 19 Upvotes on 18 Posts
Although that dent is pretty deep, I have had some luck with steam. place a damp washcloth over the dent and then put a hot iron over it allowing the steam to soak in. repeat several times. it causes the wood fibers to swell and can shrink the dent somewhat. you might need a coat of poly after and a little careful sanding. success will greatly depend on the damage. broken or cut wood fibers will not regain the old shape but compressed fibers might.
- Peter
Old 02-19-24, 03:23 PM
That crossed my mind, too, Peter, but I've never tried it with anything that major. No harm in trying, I wouldn't think.
