Vapour barrier in metal shed after insulating
Hi all,
I have a small metal skinned shed, its fairly air tight as it stands, 100% water tight (and surprisingly little condensation) and will in the near future be heated + forced ventilation.
I have battoned out interior (walls and roof) and lined the interior with RWA45 (I acquired cheap and wanted some noise reduction), I have got to the point where I can board it all out but have read I should install a vapour barrier.
it occurred to me that the metal skin is going to act as a vapour barrier itself, all be it on the wrong side of the insulation.
So do I skip this step as I don't want to trap moisture between the interior and exterior walls?
This in the UK in case it helps.
If it is ribbed, the metal will not likely be air tight, which negates any value it has as a barrier. We don't know your climate to recommend a vapor barrier or not, but the latest science says that a class III vapor retarder is sufficient in most climates. Latex paint applied to drywall qualifies as a class III vapor retarder. IMO, that is all you need.
