Building a batting cage in & out of my garage
Hi, I want to build a batting cage in my garage that will extend into my driveway about 20 or 30 feet and be able to easily take it down or take it apart obviously with more concern for the driveway but less so in the garage. I am thinking for the garage just a simple cable on each side from joist to joist however I can't think of a viable option for a removable option outside to meet the netting in the garage for a longer batting cage. Any ideas would be much appreciated!
Set two inserts/sleeves in the ground that two 10' poles could slip into. You can run the cable across the driveway and from the garage to each pole.
Pvc pipe cages with 3 way pvc elbows at the corners. If you build three 10' boxes, making each one slightly smaller than the next, they would fit inside one another if you wanted to push them all back in the garage without completely disassembling them.
