Rotting Garage Door
Old 05-14-18, 03:14 PM
R
Question Rotting Garage Door
Hello DIY,
My garage door is rotting along the bottom, I was wondering if there is anything I can do to repair this besides replacing the entire door?
I've looked at wood hardeners and wood fillers but the problem seems that this rot goes through to the other side.
If I remove the rot I have a long big hole, not sure how to really use wood filler if there's nothing to back onto, I've got a few pictures here:
https://imgur.com/gallery/S3FM9JO
Any advice or solutions are appreciated!
Thank you
Old 05-14-18, 03:34 PM
XSleeper's Avatar
Received 665 Votes on 615 Posts
Hard to tell what we are looking at. Are these double doors? If so, you probably need to remove the doors, use a skilsaw to make a perfectly straight cut across the doors and remove the rotten wood and replace it.
Old 05-14-18, 04:00 PM
P
Received 618 Votes on 571 Posts
The wood can be replaced. Much will depend on your tools and skills. The flat panels are likely held into the wood frame pieces tongue and groove. I usually fix them by replacing the wood as best possible and reinforce it on the inside with steel or aluminum plates.
Old 05-15-18, 02:24 AM
Received 312 Votes on 278 Posts
I agree, either replace the entire board or at least remove ALL the rotten wood and replace that portion [dutchman] Wood fillers don't work well if there is any rotten wood left.
