Car reversed into garage door; door slides a bit wonky now
Old 05-21-18, 08:19 PM
C
Received 26 Votes on 24 Posts
A family member reversed into the garage door while it was fully closed. It was a pretty light impact given that the rear of the car was only a couple of feet from the door when the car was parked. The door still goes up and down, but near the end of the down phase, the rollers bounce around more than they used to.
Here's video of the door. https://youtu.be/Od3dFzxm_dQ
Notice how the rollers by the top right side of the door bounce around as the door is near fully closed. I don't see any obvious track deformities from the accident. Is this something I should worry about in terms of motor failure? I'm not worried about the springs - I replaced those myself very recently and installed safety cables.
By the way, if you noticed the other thread I made about a non-functioning garage door opener (link), this is a 2 car garage. The non-working door is the other door in the video (and it's disconnected from the trolley).
Old 05-21-18, 08:26 PM
XSleeper's Avatar
Received 855 Votes on 783 Posts
Might be just me, but the bottom edge of the top track looks bent in one spot where the roller jumps as its coming down.
