steel studs for exterior shed walls
is it possible to use steel studs for exterior walls in a 14x16 shed with a plywood floor?if so,what spacing should i use?thanks
I'm not real familiar with steel studs but occasionally you'll see a whole house framed with them, including the exterior walls. Just remember anything [siding] you attach to the studs will need to be screwed on.
