Lower part of shed is beginning to rot – options?
Old 06-10-18, 06:09 PM
I have a shed that is going on 24 yrs built by a local company after we picked the design. I try to maintain it by painting and replacing rotted wood (door trim).
I recently got a new roof added 3 yrs ago thanks to my brother-in-law. He said the original never had tar paper. Luckily, there was no damage to the wood on the roof.
In any case, the attached pics show the issue. On the bottom, the wood is beginning to rot. I have been trying to patch and paint but this is happening in each section. I think it is from water coming down off the roof and splashing up under and on the lower part.
I am planning on putting gutters on so the water is channeled away from coming down the sides.
Instead of replacing all the wood panel sections, since most of the middle and upper parts of the shed are ok, I was wondering if there is something cheaper than replacing several sections of what I think is some type of T1-11?
I would like something that is about a 12 inches high that could be cut and place over the lower part where the wood is beginning to rot.
thanks
Old 06-11-18, 03:23 AM
Siding close to the ground like that is always subject to failure. Gutters may help but there is also rain splashing up from the ground and snow [if you have it]
I'd cut off the bottom portion of siding, install flashing and a 1x4, 1x6 [whatever size is needed] either using pressure treated or plastic/vinyl.
Old 06-11-18, 06:08 PM
I am not sure how to "cut off the bottom portion of siding" the entire length of the shed?
Flashing - what type would be good and how is it installed ?
I looked at Home depot and Lowes web site,,i don't see gray 1x6 vinyl.
If pressure treated wood is used, I would need gray stain?
thanks
Old 06-12-18, 04:04 AM
I think it's called PVC trim you'd have to paint it to match.
You use Z flashing, it goes under the siding, juts out 3/4" and then down a little on the wood strip below.
Take a skil saw with the blade set to the depth of the siding to make your cuts. Tacking a straight board above the cut as a guide will help you keep the cut straight.
Old 06-27-18, 06:55 PM
Ok,
PVC -> like this?
https://www.homedepot.com/p/Veranda-...RWS4/100290245
You mean a circular saw ?
That seems like it may be tough hold it at that angle and cut...
There is not a lot of room under the outside panels, in some areas no sapce for the below to slide under
https://www.homedepot.com/p/Amerimax...0120/100087282
Old 06-30-18, 03:37 AM
If you screw a straight edge to the siding at the appropriate point you can use it for guide/fence so you can cut a straight line.
This is the type of flashing you'd use - https://www.lowes.com/pd/Union-Corru...ashing/3499684
Old 08-17-18, 08:26 AM
I am going to look at the PVC, although it is more money than i expected. My brother -in-law is coming down to help.
To cut the lower 5 - 6in off the t1-11, is it necessary to remove the edge/corner trim boards as seen in the picture? They are not the same type of trim that is on the doors
They are are on tight and have not rotted and if i remove them, i am wondering if it may break, i won't be able to find a replacement
Old 08-17-18, 09:21 AM
B
Stanj, you are right. Nothing is simple in DIY world and the least expensive solutions always seem to be the hardest to accomplish. Offer some things to consider. Can you get replacement T1-11with the same groove spacing as existing? If you don't remove the trim at the door and corners. you will have 3 edges to seal instead of 1 (it appears the corner trim was nailed into a 90 degrees before installing so removal is impossible without ruining one of the boards). Also, if the shed studs are more than 16 inches apart, I would install bridging between studs at the cut line for nailing to prevent the 2 pieces from moving in opposite directions between the studs. Make sure to use the Z flashing along the cut line. Good luck.
Old 08-17-18, 10:11 AM
i... the edge/corner trim boards as seen in the picture? They are not the same type of trim that is on the doors
Those look to be common 1x3s or 1x4s
Old 08-17-18, 06:53 PM
i am wondering why the edge trim never rotted and the white trim on the doors does rot
Old 08-17-18, 07:59 PM
XSleeper's Avatar
Received 1,580 Likes on 1,416 Posts
Your corner trim might be Miratec. They might have replaced the wood already.
Old 01-26-19, 10:51 AM
Following up on the job.
My brother-in-law came down in August and over a weekend we did all 4 sides.
Attached are a few pics
Old 01-26-19, 11:25 AM
XSleeper's Avatar
Looks good! Thanks for the photos!
