Help: Garage Door T Handle issue
i have a manual open garage door with a T handle. The t handle has alot of movement back and forth from inside to out and vice versa. If you push it from the outside in the plate will jump off the lock and door will be unlocked. Prob has about 1/2-3/4 of play. How do i tighten it do there is no movement. I tightened all screws to no repair. Thankyou
Welcome to the forums.
Those handles are replaceable as a kit as they can get worn out.
There is usually a one-way slide on-clip that holds the turning/locking disc on the handle shaft.
