Garage Door Remotes Close Door but Won't Open
Old 11-02-19, 04:56 AM
R
Exclamation Garage Door Remotes Close Door but Won't Open
I have a Genie Pro Stealth Model GPS1200IC that is all of a sudden having trouble with all of its remotes. The wall switch works fine for raising and lowering the door, but the three remotes, as well as the pin code entry remote, do not work to raise the door. They will lower the door, but not raise it. I ave verified that the vacation lock is not turned on, the sensors appear to be working since the door will close, and the remote frequencies seem to be right since they will close the door. Any ideas on why they wouldn't be opening the door?
Old 11-06-19, 10:49 AM
Geochurchi's Avatar
Received 161 Upvotes on 147 Posts
Hi, have you changed the batteries in the remotes
Geo
