Roses
Old 05-05-18, 09:02 AM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
Roses
Hi All, what should I do with my rose that looks dead after the long winter? There is a small bit of new growth at the base.
Geo
Old 05-05-18, 09:22 AM
Shadeladie's Avatar
Super Moderator
Received 348 Upvotes on 279 Posts
Not a rose authority, but I cut mine down (clip right above a thorn), even almost to the bottom if necessary. I find that encourages new growth. Also a little Miracle Gro helps.
Old 05-05-18, 11:05 AM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
Well, I'm no master gardener either...but I cut ours back to about 3 main canes (those are branches in rose speak) about 1-1.5 ft from the base, and prune off any root suckers (new growth coming through the soil or bottom of the main plant). I normally do that about a month to 2 months after the leaves have completely dropped in the winter. Back in VA we did it on Valentines Day. Out here our winters are so mild you have to go by eye.
Use some slow release rose food 3 times a year.
This is how ours look and they just started greening up about a month ago. They'll easily grow up to the eaves by fall. Already had two rounds of blooms and they need watering today...I skipped a few sessions.
Old 05-07-18, 11:59 AM
Y
Received 23 Upvotes on 22 Posts
If it is coming from below the graft.....it is root stock.
