EMT pipe for trellis
Old 04-18-19, 08:25 AM
P
3/4" EMT (electrical conduit), 10 feet long, horizontal.
If I support the pipe at the ends, will I be able to hang 2 or 3 cucumber vines on it? Bowing down wouldn't be an issue, but collapsing would be a disaster.
Thank you.
Old 04-18-19, 10:23 AM
GregH's Avatar
Super Moderator
Received 65 Votes on 60 Posts
It's highly unlikey to collapse.
If you are blessed with a large crop you could install a prop stick if it bends too much.
Old 04-18-19, 11:41 AM
P
Received 1,572 Votes on 1,413 Posts
I agree you should be OK. 3/4" is much stronger than 1/2". There will be sagging and if you notice it getting excessive stick a support in the middle like GregH mentioned.
Old 04-18-19, 08:08 PM
Received 2,977 Votes on 2,686 Posts
If you notice it sagging..... slide a 1/2" piece of EMT inside it.
Old 04-18-19, 10:20 PM
P
Thank you for the notes. Went to Lowes and bought 3/4" EMT and fittings. Placing 1/2" inside 3/4" is brilliant. Now I am upping my plan. I am going to grow watermelon (small) on the trellis as well as cucumber, knowing I can add 1/2" inside anytime with no disruption to the vines.
Old 04-19-19, 04:45 AM
P
Have you ever grown melons from a trellis? Normally you have to support the melons somehow as their weight is too much for the plant to support hanging in the air. Melons grow lying on the ground so the plant isn't carrying the weight.
Most home and garden centers sell bird netting. A piece of it can make a nice sling or diaper to hold your melon. Then you support it with a piece of rope from your trelis. Growing in the air like that also allows the melon to get a more even color/texture to the rind all the way around.
Old 04-19-19, 09:56 AM
P
Thank you for the netting idea. What I have is mini watermelon.
By the way, can I drive fence posts (t-post) with a 4 pound hammer? I would like to avoid buying a post driver for just 6 t-posts. Sorry for this silly question
Old 04-20-19, 05:49 AM
GregH's Avatar
Super Moderator
You certainly can but you may damage the ends if it is tough going.
You don't necessarily need a post driver if you have a hammer, just something to slip over the end to protect the pipe while you beat on it.
Old 04-20-19, 11:50 PM
P
I completed the trellis frame. I used 5' t-posts, 3/4" EMT, 3/4" pipe connectors, and hose clamps. Now I can tie strings for vines. Thank you for your valuable suggestions.
