Go Back  DoItYourself.com Community Forums > Garden and Outdoor Center > Gardening and Horticulture
Reload this Page >
Convert drip irrigation to soaker hose system
Old 05-26-23, 04:34 PM
D
Angry Convert drip irrigation to soaker hose system
I hooked up a drip irrigation system to a sprinkler head using 1/2" tubing and fittings. Now the wife would like to convert the system using soaker hoses rather than the drip irrigation tubing. I need help with getting the correct fittings to attach the soaker hose to the main feed from the old sprinkler head.
Thanks
Old 05-26-23, 04:54 PM
Received 3,899 Upvotes on 3,495 Posts
Did you just convert one head to drip irrigation with other sprinkler heads still inline ?
Results using that method are seldom satisfactory as not enough water is delivered to the drip.
You're connecting to the line..... not the sprinkler head.
Remove the 1/2" barb to 1/2" threaded connector and use a 1/2" barbed splice fitting to go from poly to plastic.
Old 05-27-23, 12:01 PM
D
Thank you!
