Oven bolted into floor, need to get card out from between oven and cabinet
Received 0 Votes
A giftcard fell between the oven and countertop. I haven't been able to fish it out with a coathanger. I can't get a coathanger to straighten out enough. Is there a device I can use that's better than a coathanger for this?
If I can't fish it out, I'll need to pull the oven out to retrieve it. I've been reading a bit on how to do this, but I'm stuck on figuring out how to remove this bolt, which looks like an upside-down screw. Does this mean it was bolted in from the basement? I can't find anything on the ceiling down there.
Thanks for the help
Thanks for the help
Can you see the card ? Yes.... use a yardstick with gum or putty on the end.
That item in your picture is an adjustable leveling foot. It is not holding the stove in place.
If the stove hasn't been moved in a while..... it's probably stuck in dried grease on the floor.
Similar adjusting foot.
