Replacing dryer door gasket
Whirlpool LGR5644AW0 gas dryer
I need to replace the door gasket as the old one came off and got mangled in the dryer. I show part number 3390734 as the correct gasket. What I am unsure about is the correct adhesive to mount the gasket. I see one glue on amazon as "Whirlpool Y055980 High Temperature Adhesive" but that cost seems high for one use. Am I looking at the correct adhesive? Is there something I might have at home (gorilla glue?) that can work or something cheaper to buy?
Also, what do I use to remove the old adhesive from the door without harming the finish and still be able to dissolve the glue?
- Peter
- Peter
High temperature adhesive is not required. A contact cement is. Coat the gasket and the metal. Allow the cement to setup and then press in place. Bonds instantly so make sure it's in the right place.
I use a professional 3M adhesive but it's very expensive.
My second choice is Good Year Pliobond.
Pliobond-P141-1OZ-PLIOBOND-ADHESIVE/dp/B00176HL9Y
A good easy to locate product is Weldwood contact cement....
DAP Weldwood 3 fl. oz. Original Contact Cement- The Home Depot
Use lacquer thinner sparingly to remove the old glue.
