Gas Grill - Broken Hood
Old 07-31-16, 04:38 PM
C
Hello,
After my gas grill took a tumble off the deck earlier this year the hood was left with the gash pictured below. I checked the gas tank/line, etc before using and all was well. Is it okay to seal this crack with some type of high heat sealant or foam? My goal is to limit heat loss. Thanks
Old 07-31-16, 05:38 PM
chandler's Avatar
Received 9 Votes on 8 Posts
I know of no high heat foam that would fix this. I would obtain a piece of metal, say 2" wide and 4" long, drill holes in the metal and the hood, fixing the metal to the hood with stove bolts on either side of the gash, tightening them down to close the gap if possible. It may look better to have the metal on the inside and the bolt heads on the outside.
Old 07-31-16, 05:41 PM
C
Received 28 Votes on 23 Posts
I suggest you get a piece of stiff aluminum (could use steel but it will rust) shaped to fit behind the cracked area with at least an inch or so overlap past the crack. Clamp it in place and drill through the cover and the plate and pop rivet it all together. The big box stores sell small pieces of aluminum and steel.
Old 07-31-16, 07:22 PM
Norm201's Avatar
Received 594 Votes on 531 Posts
You could try some of the high heat resistant epoxies. JB Weld comes to mind. It's good to 400 degrees. But if your grill is being used beyond typical temps that the body is higher than 400 degrees, I'd say your cooking way to hot.
There's also Blu Magic. Good to 2400 degrees.
Blue Magic/QS High temperature metal repair trilingual 18003TRI- ReadReviews onBlue Magic #18003TRI
Most muffler epoxy might work also.
Old 08-01-16, 05:44 AM
Tolyn Ironhand's Avatar
Received 595 Votes on 511 Posts
What material is the part made out of? You might be able to have somebody weld/braze it together.
Also post the grill maker and model. There are many replacement parts available on the internet.
