Shutting off gas ONLY to dryer
Old 02-26-18, 04:36 PM
R
I recently sold my gas dryer. I closed the gas valve before unhooking the dryer. But now my stove is not working. How do I shut off the gas valve ONLY to the dryer and keep gas going to the rest of my house. It was built in 1960s, so kinda old.
Old 02-26-18, 04:39 PM
Gunguy45's Avatar
Super Moderator
Received 4 Votes on 4 Posts
There should be a shutoff for each appliance. If not you should add one, then cap the output. If you don't want to do that, just cap the line to the dryer.
Old 02-26-18, 07:46 PM
R
Awesome. Thanks. I just went to home depot and bough the valve
Old 02-26-18, 08:30 PM
Gunguy45's Avatar
Super Moderator
You can't trust just the valve. You need to cap the output of the valve as well. That may require a nipple into the valve and then a cap on that. Make sure to use the correct pipe dope/tape. Gas tape is yellow...read the label on the dope.
