Propane stove flames turned orange
Old 12-01-18, 05:58 PM
F
Recently we had to re level our propane tank due to it sinking into the ground on one side. Right around the same time I noticed the flames on my stove turn from blue to orange. I didn't pay much attention to it until we were replacing our over the stove microwave. Which was a major ordeal. Its been several weeks now and the flames are still orange with just a little blue at the orifice. I know orange flames are not what should be burning. What do you suggest?
Old 12-01-18, 07:33 PM
Received 23 Upvotes on 18 Posts
An orange flame indicates incomplete combustion and it is not safe to operate the stove. It is likely producing increased levels of carbon monoxide, which obviously isnt a good thing. Could be a bad regulator on the tank or the stove may need adjusting.
Any chance you are running a humidifier in the house? Excessive humidity can also cause propane flame to burn more orange than blue.
Old 12-01-18, 08:29 PM
Received 3,480 Upvotes on 3,125 Posts
Welcome to the forums.
I'd recommend calling your propane provider and have them check the pressure levels ASAP.
It definitely sounds like a regulator issue and the pressure is too high.
Any propane device connected could be burning improperly.
As mentioned..... CO is a very real and dangerous problem from flames like that.
