Oven thermometer broke off
Old 04-30-19, 10:23 PM
L
The thermometer to my oven that connects to its thermostat snapped off the other day. Now when I turn the oven on it just goes at full heat all the time. The stove is an old GE hotpoint, model RGB5241F0AD. I have attached some pictures that show the model number and thermostat. Can anyone advise one what to do?
https://i.imgur.com/PEpJumF.jpg
https://i.imgur.com/GmZYNvJ.jpg
https://i.imgur.com/VV5139f.jpg
https://i.imgur.com/af1usqu.jpg
https://i.imgur.com/q0jVsVy.jpg
I can't reattach the thermometer probe to it's wire by soldering can I?
I assume I will need to purchase a replacement. Will I need an entire thermostat or can I just get the thermometer probe?
Old 05-01-19, 03:08 AM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
Model # did not work. Tried to read tag but to small for me.
Old 05-01-19, 03:41 AM
Norm201's Avatar
Received 725 Upvotes on 641 Posts
Pugsi, does this help?
Mod# RGB524 the B might be an 8 or P
S/n 16398B41
Old 05-01-19, 07:13 AM
pugsl's Avatar
Look at part # 26 in second picture, Google part # I found several different places with that part but was 147$.
https://www.searspartsdirect.com/mod...1/0124200.html
Old 05-01-19, 04:03 PM
Received 3,976 Upvotes on 3,569 Posts
According to Sears parts..... your safety valve could be a WB21X374 or WB21X5231.
I checked at a dealer and found it could also be a WB21X5232. This valve should be able to be replaced by a universal type widely available.... 5817S0007 gas safety valve kit. The link is one place to get it. That dealer can confirm it's what you need. This is a kit..... NOT a direct fit so some work is involved.
Gas safety valve kit
Old 05-01-19, 06:32 PM
L
I was able to find it here, this is my stove RGB5241F0
https://www.appliancepartspros.com/s...el=rgb5241f0ad
https://www.appliancepartspros.com/p...rgb5241f0.html
WB21X5231 but out of stock =(
Pjmax what would the kit entail? Can I just switch the thermometers?
Old 05-01-19, 09:46 PM
It's not a thermometer.......... it's an actual thermostatic gas valve.
The kit comes with different mounting brackets and brass gas line adapter fittings.
