LP to natural gas conversion for stove
Old 05-08-19, 09:40 AM
V
Question LP to natural gas conversion for stove
I am connecting a new Kitchenaid gas stove to a large liquid propane tank. I can find plenty of conversion kits that are for connecting you LP grill to a natural gas system, but none that say specifically to go the other direction. Do I simply just run the same conversion kit backward?
Old 05-08-19, 10:41 AM
P
Received 1,953 Upvotes on 1,749 Posts
There should be specific conversion instructions included with your stove. Many stoves come with the kit to convert them from one fuel to the other or it's ordered as a separate item.
When I remodeled my kitchen the stove came for natural gas and the propane conversion kit had the instructions and parts needed. I had to make an adjustment on the regulator on the appliance (hidden behind the bottom oven drawer) then replace the jet for each burner.
Old 05-08-19, 08:03 PM
Received 3,619 Upvotes on 3,245 Posts
Many gas appliances come with the LP conversion orifices.
If yours didn't.... post the model number or you can check at the link below.
KitchenAid conversion kits
