Does the gas regulator provide gas shutoff?
Old 09-08-19, 08:48 PM
Q
Hello all,
I have the maxitrol gas regulator model 1307 88/801097-B.
Question> Dos the gas regular have a switch to turn off gas to the stove or I have to turn off the whole house gas valve in order to service the stove if needed?
Thank you
Old 09-08-19, 10:56 PM
Received 1,194 Votes on 1,105 Posts
That regulator does not have a shut off on it. Most regulators don't.
Many ranges have the regulator inside the appliance and there could be a shut off next to it.
In any event..... you should have a valve behind the range on the supply line.
That valve is used for service as well as replacing the range.
q0987 voted this post useful.
Old 09-09-19, 05:55 AM
P
Received 684 Votes on 631 Posts
No, most/all interior use regulators do NOT have a shutoff valve. They are regulators only. The lack of a knob or lever of any type on yours confirms that it does NOT have a shutoff valve.
In my area it is required to have a 1/4 turn gas shutoff valve at each appliance. It must be installed on the rigid line. It cannot be installed on the appliance end of the flex line.
