Wolf Gas Range - Burner "drift"
Old 12-26-19, 03:01 PM
When turning the burner knob to the desired level, once I let go, it moves by itself and reduces down to the lowest setting. It takes a lot of very delicate turning to get it where I need it. It started about a year ago and has gotten progressively worse. It's happening to each of the 6 burners, but much worse in the ones I use the most.
Is there an easy way to adjust or tighten the burner valve?
Any help is much appreciated!
Old 12-27-19, 10:47 AM
Received 2,954 Votes on 2,665 Posts
Welcome to the forums.
Not a common problem on a higher end range.
Doubtful they can be tightened
How old is the range ?
What is the model number ?
Old 12-28-19, 06:22 AM
Itís a Wolf GR486C, about 5 years old.
Old 04-03-20, 06:08 AM
L
Wolf Burner drift
I have the same issue with a 4 year old Wolf range. Did you find a fix?
Old 04-03-20, 09:21 AM
I don't see a way to service those valves. Looks like replacement may be the only choice.
If I paid a lot of money for a high end range I'd certainly contact the manufacturer for assistance.
In checking at their site I don't see much assistance available other than factory service.
Sub-Zero/Wolf
Old 04-11-20, 08:15 AM
Unfortunately, no - I'm going to contact the showroom. Will let you know what I find.
