Can I Use this Replacement Trap Assembly?
Old 06-21-16, 03:29 PM
U
Hi. I have a Haier Furnace model HGV090N3H,http://www.alpinehomeair.com/related...spec_sheet.pdf . The part of the trap assembly, where the assembly connects with one of the hoses, has cracked, so the hose cannot connect with the trap assembly. The cracked piece from the trap assembly is currently stuck inside the hose that was connected to it. Will this product, the Meridian 4223700 Trap Assembly for 90% Furnace, https://www.plumbersstock.com/meridi...nsate-vsa.html work as a replacement? Haier makes a replacement trap assembly but it is about 10x more expensive. Thank you.
Old 06-24-16, 08:02 AM
U
Hi. No one has any thoughts on this?
Old 06-24-16, 01:58 PM
A
Received 44 Votes on 39 Posts
The amount of aggravation you will go through trying to use that substitute may not be worth the savings. If the outlets are not in the right orientation or worse, the right size, you could have air leaks with exhaust gases coming into the house.
