Basic Wiring Help
Old 07-09-16, 03:52 PM
N
Question Basic Wiring Help
Im about to replace my old non-digital thermostat with a digital one from Honeywell.
Old Thermostat:
New Thermostat:
On the old one, there is Rc and Rh, but the new one has Rc and R, I was wondering if R takes the place of Rh or do i need to wire it someplace else.
I have a Central heating and cooling system for the house.
Old 07-09-16, 04:19 PM
Houston204's Avatar
Received 94 Upvotes on 87 Posts
Yes, R and Rh are the same thing. It looks like you have a jumper between the R terminals on the existing stat. I would jumper the R terminals on the new stat as well unless the instructions state otherwise.
I see that the toggle is set for HP. Did you just bump that?
Old 07-09-16, 04:50 PM
N
No experience with wiring or thermostats
I have absolutely no experience with these things, I don't know what Jumper means, also I think that switch was preset to HP, not sure what it means.
Old 07-09-16, 05:35 PM
Houston204's Avatar
With the switch at HP I would expect the outdoor unit to be energized on demand for heating or cooling. Heat pumps would use this setting.
Since I do not see a wire at O or B it is unlikely that you have a heat pump.
It looks like the red wire connects to one of the R terminals and a small piece of wire is used to connect the R terminals to each other. This piece of wire used to bridge these terminals is a jumper wire.
Old 07-09-16, 07:38 PM
N
I hooked everything up, its working perfectly, thank you for your insight.
