Intermittent Aux and Emergency Heat
Received 0 Votes
Hello
System: Heil 9UHX gas furnace, outdoor heat pump connected to Honeywell HZ432 zone board.
Issue: Having issue with both AUX and Emergency heat. Due to outside temp, the heat pump is locked out and normally AUX runs. AUX comes on and runs for about 1-2 minutes, then system shuts down. When the time cycle ends, the process starts again. I tested the system by manually setting to emergency heat, same issue. What would cause the system to keep shutting down and starting cycle over.
Thanks JR
Thanks JR
Received 0 Votes
Hello,
I am getting 26 volts to zone board.
Strange issue. I have three zones on this board, and have two off right now. Zone 1 just kicked on, and thermostat showed 68 in the room and 68 to keep room temp, so not sure why it went into heat mode. Then it show heat on the screen, and not AUX heat, so it should be using the heat pump, but furnace was using natural gas? Both thermostat and zone board showed heat one meaning heat pump and not AUX. Normally when furnace uses the natural gas, thermostat shows AUX and zone board shows heat 2?
Thanks Jr
Thanks Jr
Received 0 Votes
Forgot one thing. When system shuts down, all zones go green for a few minutes, then zone 2 goes red, usually meaning call for heat. I have that thermostat off. So zone board shows zone 2 red (on), but nothing in the system is ramped up, all at idle.
JR
JR
