Stacking filters
Old 01-18-17, 10:03 AM
G
Received 1 Vote on 1 Post
Stacking filters
My system uses expensive 20X25X5 filters. Yesterday at the hardware store I noticed there are also 20X25X4 filters of the same type. Would it be a good idea to pair a 4" box filter with a cheap 1" ahead of it to catch most the dirt?
Old 01-18-17, 10:11 AM
F
Received 35 Votes on 27 Posts
Just use the four-inch by itself. You could also cut some one-inch wooden spacers if necessary to keep the outlet face of the filter tight against the furnace intake.
Old 01-18-17, 07:27 PM
G
The 4" is only a dollar cheaper--i was just wondering if anyone puts a "pre-filter" ahead of theirs to make it last longer.
Old 01-18-17, 07:58 PM
R
Received 103 Votes on 97 Posts
There's no need with a media like that. Best to just use the 5" for minimal pressure drop. The 5" has plenty of capacity to handle all the debris that flows through it.
Old 01-19-17, 03:55 AM
chandler's Avatar
Received 6 Votes on 6 Posts
Use what is called for. My obsolete electronic filter housed 5" electric plates. Once removed the 5" media fit right in. I did have prefilters stacked on the intake side in their own slide. They are a great boost to help keeping the media filters free of a bunch of larger stuff like dog hair. I change the media filter once every 6 months, but remove the metal pre filters almost every month and clean them.
Old 01-19-17, 04:15 AM
Geochurchi's Avatar
Received 73 Votes on 69 Posts
Shop around on line for better prices on the 5",stick with what the system was designed for.
Geo
Old 01-19-17, 06:44 AM
G
Larry you contradicted yourself. You changed from electronic to media.
(ETA) If you didn't already have the pre-filter left over from the electronic housing--don't you think it would be a good idea to add one?
Old 01-19-17, 01:54 PM
chandler's Avatar
I didn't contradict myself, although my wife accuses me of it often I was lucky to have that electronic casing in place when I decided to change over. By all means if there is a method that will allow you to add prefilters, even if it is somewhat ahead of the media, I say do it.
