Furnace terminal connection
Old 04-22-17, 10:26 AM
I'm connecting smart thermostat, and was missing the common wire. So I ran a new cable to to the furnace, however I don't have the normal terminals and wondering if it's possible for me to hookup the common wire anywhere on the unit.
https://i.imgur.com/BlPL8fK.jpg
https://i.imgur.com/2Kf7thp.jpg
https://i.imgur.com/SCduf1R.jpg
Unit diagram picture
https://i.imgur.com/ye5WQLK.jpg
Thank you
Old 04-22-17, 10:48 AM
Received 1,595 Votes on 1,470 Posts
Welcome to the forums.
If you have A/C...... the top two wires will be connected to the outside compressor.
Old 04-23-17, 07:13 PM
T
I honestly think that's a misprint on the diagram. The BL is the common, but there would be no reason for the BL/BK to go out to the condenser because all it will do is get nutted together with the BL there anyway. It's the common side of the fan relay (circuit completed by a G call). Condensers only require two leads, Y and C (unless they are multistage or heat pumps, which is not the case here).
Old 04-23-17, 07:24 PM
Yeah.... that is strange. I never traced it all the way back until you mentioned it.
So in this case it would strictly be the Blue C line and the Y to the outdoor condensor.
Old 04-23-17, 07:43 PM
A
Received 58 Votes on 51 Posts
If not a misprint then at least confusing. Look at the ladder diagram and note 5. BL and BL/BK are to be wire nutted together in the field, not factory.
