New furnace installation in garage
Hello
I'm putting a new furnace in my garage, new construction. I don't have much faith in my original contractor and he's expensive to boot. I'm sure I can handle with some guidance
I've got the furnace, 25 ft each of 7" and 12" insulated ductwork and a couple sections of metal ductwork. If possible I would like to use what I have and add if neccessary
The ducts will be in the ceiling, garage has a second level so they are floor joists, 2x10. My thought is to run the return line down one joist opening and then probably 2 lines for vents down 2 others.
Furnace will be in the attic, I've been told if I insulate it then it can be there and shouldn't freeze.
I need to figure out something for filter(s) to be accessible from the garage side if possible.
I can add photos if needed if I'm not explaining myself very well
Thank you
Thank you
Adding some pictures, please click on links to view
Furnace I will be using
https://1drv.ms/i/s!AlMKyRBHlUsBgak64EFRP1VRT-sIgw
Where it will be sitting, I've been told to build a stand in the trusses and mount it horizontal. I don't see what I can't just set it upright over the supply hole.
https://1drv.ms/i/s!AlMKyRBHlUsBgak7B9aOfeWU_kMKNQ
https://1drv.ms/i/s!AlMKyRBHlUsBgak8TMPp_U3j6IBkZw
Floor joists as viewed from the garage
https://1drv.ms/i/s!AlMKyRBHlUsBgak5mOGFGVwIg1e8kg
