Furnace Parts Online
Old 01-03-18, 11:33 AM
T
Im looking for a comprehensive parts store online for my Luxaire furnace.
Not having much luck. Canít find anyone that carries or lists the condensation
tank / trap that the inducer fan bolts up to. Mines leaking and itís time to
replace it after 2 silicon sealer repairs. Have done model number searches along with brand name with no successful results. Seems like this would be a common maintenance part that should be easy to locate 🤔
Any suggestions anyone? Thanks!
Old 01-03-18, 12:10 PM
P
Received 687 Votes on 634 Posts
Post your model number but I found what I think are the parts at the first place that popped-up.
Old 01-03-18, 12:49 PM
Received 50 Votes on 47 Posts
T,
www.repairclinic.com
In the search bar type in Luxaire and model no. if you have it and an extensive list of parts come up.
Hope this helps a little.
Old 01-03-18, 05:16 PM
T
Repair Clinic does not list the part I need.
My model number is:
LP9C080B12MP12CA
Old 01-03-18, 05:40 PM
core's Avatar
Is this not it?
https://www.repairclinic.com/PartDet...P9C080B12MP12C
Photo from the other side:
Old 01-03-18, 06:00 PM
Received 1,203 Votes on 1,113 Posts
You can use the actual parts manual to locate your part and part number and then google the part number. York_Redirect/035-22758-001-H-0712.PDF
Even amazon has that part available.
Old 01-03-18, 07:09 PM
This is what I found on the sight.
Luxaire Furnace Drain Pan
RepairClinic Item # 3277340
This part fits your Furnace
Condensate pan
OEM Part - Manufacturer #S1-32816419000
Old 01-05-18, 08:03 AM
T
It looks like it Yes! The one on the furnace is clear but that would not matter
