cleaning gas jets
Old 01-09-18, 10:25 AM
T
cleaning gas jets
I have a Goodman GMNT 060 forced air furnace. The middle burner flame is smaller than the other two, and also a different color. More purple/blue than blue. I think it's running on a lean mixture. My question is how to clean the jet without damaging it. Can I remove it and if so can I probe the orifice safely? If it's removed, then when replacing it, what sealant, if any, should I use?
Any help would be appreciated.
Tonyc72
Old 01-09-18, 10:35 AM
Received 2,787 Votes on 2,524 Posts
Most orifices are removable. It doesn't need any sealant on the manifold. You can use a small piece of wire, pin, small drill bit or a bristle from a wire brush. You just want to clean the opening without enlarging it.
Old 01-11-18, 09:37 AM
T
Thanks Pjmax. I did as you suggested and it seems to have been the problem.
Thanks again for your help.
Tonyc72
