manometer accuracy
Old 02-12-18, 09:20 PM
P
manometer accuracy
What is a good reasonable priced accurate manometer to measure my barometric damper?
My furnace should be 0.025 and my flue should be -0.02. Looking at the gauges for sale i see accuracy (read
inaccuracy) ratings that would make readings in the range that I need almost useless. Exp:
0.3% of full scale 55.00wc (0.003x55=0.165) Does that mean that a reading of 0.02 could be off by as much as 0.165?
+/-0.3% of full scale 83.02 InH2O NKTECH NK-L3 (0.003x83.02=0.249)
±1.5% of full scale 4.00wc Dwyer 478A-0 (0.15x4=0.6)
Am I doing something wrong here?
tks,
pa
Old 02-13-18, 07:14 AM
P
Received 686 Votes on 633 Posts
I would look for a instrument that is more appropriate for the pressure you're trying to read. A gauge capable of reading up to 55" WC is way too high for your very low pressure application. It's like using a 3'000 psi gauge to check the 30 psi in your car's tires. There are gauges that max out at .5 so any inaccuracy would be very minimal. Dwyer makes some simple plastic gauges that are quite inexpensive and has the scale expanded at the low end for increased accuracy and probably would be perfect for what you're doing.
Old 02-13-18, 07:37 AM
P
none that Ive found. that dwyer shown +/-3.0 of 3.0 is 0.09, so a reading of 0.02 could be anywhere from 0.11 to -0.07
Old 02-13-18, 09:25 AM
P
I would not over think it. A liquid in tube meter is about as accurate as you can get without spending a lot of money. Much of the accuracy will come from how level you install the gauge and set the zero.
Old 03-07-18, 05:24 PM
P
manometer accuracy take 2
I need to measure -0.02 and +0.03wc.
mount it inclined 10:1 for 10 times the resolution. https://www.amazon.com/Yellow-Jacket-78075-Water-
Manometer/dp/B0038QHTK2/ref=sr_1_5?ie=UTF8&qid=1520466840&sr=8-5&keywords=manometer
its graduated at 0.25 intervals and you can easily judge 1/5 of that. So, 0.25 included 10:1 the 0.25 would then be 0.025 and I could fairly accurately judge 1/5 of that or 0.005.
thoughts?
Old 03-07-18, 05:29 PM
P
Old 03-07-18, 08:28 PM
Received 1,201 Votes on 1,111 Posts
Take 2 ???
A single topic is contained in a single thread. Threads combined.
Old 03-07-18, 08:39 PM
B
Received 37 Votes on 34 Posts
Minneapolis has upgraded their manometers to the DG1000 so you might be able to pick up a used DG700, still expensive but certainly can measure pressures with the accuracy you are asking for.
https://www.ebay.com/i/302660358408?chn=ps
Bud
Old 03-07-18, 09:01 PM
P
Originally Posted by PJmax View Post
Take 2 ???
if you dont fully understand and combine threads you do a disservice!
