Heater turns on for a minute, then off
Old 02-25-18, 08:44 AM
B
Hi all,
My heater turns on and runs for a minute or so then shuts off. Temp is still way below what it should be so 30 seconds later it starts to kick on again. Turns on and off. Repeats this process until it shuts down completely and I have to reset things.
After some research here I assume it was a dirty
flame censor. After opening things up Iím not sure if my furnace has one so Iím stuck at this point.
My furnance is OLD. Bryant Day&Night. Manual says model 394 & 396.
Here are some pics.
https://imgur.com/a/A7IFm
Old 02-25-18, 09:04 AM
Received 2,955 Votes on 2,666 Posts
That furnace uses an intermittent ignition system where the pilot is spark lit. It doesn't have a conventional flame sensor rod. It has a pilot assembly that includes an igniter/sensor assembly.
The full model number should be on an ID tag in that area.
Has the unit been professionally cleaned ?
It should be done every year or at least every other year. On an older furnace the heat exchanger is checked for cracks and rust thru.
Old 02-25-18, 09:21 AM
B
Hereís the model information
https://imgur.com/a/kaqG5
so are you recommending just having someone come out and service it?
thanks!
Old 02-25-18, 10:21 AM
XSleeper's Avatar
Received 1,528 Votes on 1,372 Posts
Some heaters shut off then run again for a short period of time to dispense the residual heat on the heat exchanger. The heater in my former apartment was almost identical to yours... And that's the way it worked, so i would say it's normal. Unless you are saying that if you turn the thermostat up from 65 to say, 70F that it still only runs for 1 minute...
Old 02-25-18, 10:41 AM
B
Xsleeper - my house is 63 right now and I want it to be 70. It doesnít even move up 1 degree when it kicks on at this point.
Old 02-25-18, 10:47 AM
Have you checked and replaced the air filter ?
Your furnace may be shutting down on overheat.
Old 02-25-18, 10:49 AM
B
I changed the air filter about a month ago.
Old 02-25-18, 11:31 AM
My preliminary lookup shows a control board with a fault LED. See if there is a sight glass thru the blower door.
Old 02-25-18, 11:43 AM
B
Hereís inside the blower door. Not sure if this is what you are referring to.
https://imgur.com/a/bgdUM
