Cracks in furnace transition box
Replaced the draft inducer motor in my Keep Rite furnace and saw a couple of cracks in the transition box. Furnace is working and this has probably been like this for a while. Pics attached. How critical are these?
That looks like a crack in the heat exchanger. That would mean the end of the furnace. It would be extremely expensive to replace the exchanger.
X2, it appears your heat exchanger may be cracked.
I’d not recommend running the furnace if so.
Take off the collector box and see.
So can you explain why this happened? I am currently out of heat at the moment my draft inducer stopped working it was making a funny noise for a while now and stopped working tonight like it’s seized up. Well I took it off to make sure that there wasn’t anything blocking it and noticed my box looks just like your picture with the crack at the entrance.
Not sure. Based on the poor placement of the hose clamp which dug into the box, I was leaning towards shoddy installation. When installing the new one I noted that it would be quite easy to overtighten the screws. Maybe that's what happened and caused it to crack.
I typed the model number
I had the exact same issue on my Comfortmaker Furnace Model# N9MP2050B12c. Like LakeEffect, I suspect this was due to shoddy installation or possibly it's just an design flaw. Plastic doesn't seem like the best material to use for something that's gets wet and very hot (it's located near the burner assembly and the draft inducer. Plus, my furnace is installed in a fairly enclosed space which tends to make it run hotter than I think it should. Regardless, I think replacing the transition assembly is all that is needed. I discovered this issue while replacing my draft inducer motor.
