Hot surface ignitor question
Old 04-04-18, 03:43 PM
C
I have a Carrier Weathermaker 9200. It was not working and had code 34 that I narrowed down to the HSI(Hot Surface Igniter) So I replaced it and the furnace fired right up and is working. The only thing is the HSI is staying red hot while the gas furnace is on. Is that normal? I would think it would click off after the flame is lit. It does turn off normally when the thermostat reaches temp and clicks off when furnace is not running.
Thanks,
Chris
Old 04-04-18, 04:56 PM
R
Received 103 Votes on 97 Posts
No, that isn’t normal. Have you confirmed it’s constantly getting power?
If so that’s what killed the old one.
Old 04-04-18, 05:36 PM
Received 1,113 Votes on 1,033 Posts
Welcome to the forums.
Post the model number of the furnace. It can be found inside on the side wall near the burner. Post the part number off the control box too.
