80% Furnace vs. 90% Furnace; requires side wall venting
Old 05-31-18, 08:30 PM
C
I'm having heat/AC replaced. My furnace installation needs side wall venting. What's the better option in terms of cost and reliability...
80% Furnace with side wall power venter/damper, or 90% Furnace without the power venter/damper?
I appreciate anyone's opinion...
Old 05-31-18, 09:22 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
I would definitely pick the 90% if I needed side wall venting.
This far south we do not install many 90% furnaces unless it is an Icynene home or the furnace is in a basement in River Oaks.
The 90% seems like it would be more reliable of your 2 options.
Old 06-01-18, 05:30 AM
A
Received 58 Votes on 51 Posts
With an 80% furnace with a side wall vent don't you still have to treat it like a chimney? Double walled and when outside needs to rise above roof line?
Old 06-01-18, 03:20 PM
C
Thanks a lot Houston204 for your reply.
Does anyone know how the costs of these 2 options compare?
Old 06-01-18, 03:23 PM
C
I don't know Astuff. There are 2 stories above me, so going out the side wall is the only option.
Old 06-01-18, 03:32 PM
C
I accidentally posted the same reply twice. Does anyone know if there is a way to delete a post?
Old 06-13-18, 07:37 AM
user 10's Avatar
Received 45 Votes on 39 Posts
80% is pretty much obsolete in heating dominant climates.
Even if you could vent through the roof it would be a dumb idea to put mid efficiency anywhere the heating season is more than 2 months.
We don't have them in canada anymore, but we don't put furnaces in attics or garages where there's a risk of freezing condensate.
Reliability is about the same for 90% as is for 80%. They have the same controls - using the same circuit board, main blower motor, etc.
