New furnace installation issues
Old 11-15-18, 09:31 AM
edsjr's Avatar
I'm in Central IL, currently just using this furnace in the winter so temps are anywhere from 0 to 40 degrees (can vary by the minute lol)
2 Story house with attached garage. This furnace is for the garage only, 30' x 36'
Goodman 96 efficiency, can't seem to locate a model number. If needed I can get a picture or look harder for model number
Natural Gas.
Honeywell internet connected thermostat
So I let a guy I know from the bar put this in for me. He's got some experience but I don't think a lot, I figured it's just a garage furnace and I could make changes if I need to but he did most of the hard work
So here's the problem. It has one large air return (16x25 filter) and then 2 supply runs that each has 3 registers. The first register on the shortest run is getting the vast majority of the air flow. The next two down that run get less but more than any of the 3 on the longest run. I have a feeling this is due to incorrect size of ductwork, which is insulated flexible ducting.
What can I do to equalize this out better?
Old 11-15-18, 03:06 PM
Received 4,117 Upvotes on 3,697 Posts
Put a damper in the shortest line or put adjustable registers on.
The model number will be on an ID tag inside the furnace on the sidewall near the burner.
