Pressure Switch Stuck Closed (Again!)
Old 11-17-18, 09:21 AM
R
Hi,
My furnace is reporting "Pressure Switch Stuck Closed". While searching for information, I came across my post own here from 2013 and the behavior and symptoms are *identical*:
"Pressure Switch Stuck Closed" - Running out of Parts to Replace!
This time, cleaning the flame sensor did not solve the problem. So I replaced the flame sensor, which also did not solve the problem.
I have not replaced other parts yet. I have cleaned the condensate trap, which was gunked up. I have inspected all of the tubes/hoses/vents.
I would appreciate any advice. I don't feel like replacing several major parts like I did last time (to no avail).
Regards,
Ryan
Old 11-17-18, 10:12 AM
R
Never mind!
I retraced my steps. What I'd already cleaned and replaced this time was the *igniter*. When I cleaned the *flame sensor* that fixed it. Which was the advice I received from my referenced last post 5+ years ago.
I guess I should set a reminder to clean the flame sensor every 5 years!
