Oil pressure gauge
Old 02-02-23, 01:29 PM
Oil pressure gauge
Where can I permanently connect an oil pressure gauge on a A2EA6520 pump? This pump has the solenoid on top! Can I use either of the 2 1/8th ports on the sides of the pump?
Thanx!
Old 02-03-23, 09:22 AM
Sorry , correction, pump is Beckett A2EA6528 with 1 1/8 NPT port on each side. 1 port is used for bleeder.
Old 02-03-23, 09:51 AM
P
Received 2,326 Upvotes on 2,068 Posts
Have you looked online for the manual? It should tell you what each port on the pump does.
Old 02-03-23, 01:45 PM
No, I haven't but I believe they're both bleeder ports and I don't know if I would get the correct pressure readings!
Thanx, I'll see what I can find!
