Need new blower motor?
Old 03-16-23, 03:33 PM
F
Just wondering if someone can point me in the right direction with a compatible motor online. I Live in burnaby,canada the motor for the longest time was making noise and now wont turn on when the heat is on. Thanks
Old 03-16-23, 05:03 PM
Houston204's Avatar
Received 95 Upvotes on 88 Posts
I can't see any 31 frame belt drive motors.
You might need to measure the motor and check if a 48 or 56 frame motor along with the pulley is an option.
http://rockymountainbaldor.com/wp-co...frame-size.pdf
Old 03-17-23, 12:55 PM
Received 4,155 Upvotes on 3,731 Posts
I was searching thru some threads on Airco furnaces.
I kept coming across the 840CV as a replacement used in many of their repairs.
Emerson 840cv (specs on page)
The 266A9316 appears to be a manufacturers production number.
That number is linked directly to the 841CV motor.
The 841cv looks slightly more heavy duty.
Emerson 841cv (specs on page)
Old 03-23-23, 06:11 AM
F
Thank you for the help. I replaced it with marathon hg701 motor but now stuck on just how to hook it up. I have a white, yellow and green wire. The way I've connected it, it starts up but sometimes sparks so wondering if it's right. Any ideas?
Old 03-23-23, 01:40 PM
Sparks !!??!!?!!
It's amazing the motor didn't fry.
The two connections with the nut and bolt are for incoming power.
The ground does not connect to the board. It goes to the dedicated ground screw.
See labeled motor picture.
Old 03-23-23, 02:02 PM
R
Received 199 Upvotes on 181 Posts
The wires are installed improperly. They need run through the motor shell with the proper clamp. And the electrical cover installed.
The wires now are rubbing on the case.
As said above the wiring is connected improperly.
