Cad cell
Old 11-05-23, 02:52 PM
R
Cad cell
The cad cell in my oil burner works when I shine a flashlight on it, but when I reinstall it, the furnace locks out after the 30 seconds. Do they wear down, or are they an all or nothing item? I have 2 used ones. Both give the same result. Fine with a flashlight, but relay trips when installed.
Old 11-06-23, 02:09 PM
Received 4,148 Upvotes on 3,725 Posts
Welcome to the forums.
You're going to need a meter to make tests. Nothing complicated.
You may have a burner or air mixture issue.
You need to test the cell in operation.
Required..... a meter with test clips and a clip to clip.
You can just wrap the cell wires around the test probes.
Use a piece of thin wire to jumper Fs to Fs.
Rather than type up a test... check out this video.... Testing cad cell system - video
Ray-Davies voted this post useful.
Old 11-07-23, 07:34 PM
R
Thanks Pete
