The existing 1/2 inch glass door appears to have a seal that is glued on the edge vs one that attaches to each side of the glass.
Can I pull from bottom to remove existing seal and replace with a H shape? The position of the seal wouldn’t be in the middle of the glass as the existing one.
I hope I've reached the right place for this question. I have a piece of colored plexiglass or acrylic, not sure, that I want to repair if possible. It doesn't have to look perfect.
I was thinking possibly melting the edges together with a soldering iron or torch? Or is there a certain glue that would fuse the edges together?
Once this is back in place it won't be that noticeable or subject to much stress. Any suggestions appreciated. Thanks!
[img]https://cimg8.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/20221016_221123_ab49e0bc03e67166d9f53dad013901e9f0aeca6f.jpg[/img]
Read More
I have a large bathroom mirror over the vanity on my wife's side. There's an L shaped lip that I guess held up the mirror. On the left side, the vanity is starting to pull away, maybe an 1/8 inch gap and the mirror is starting to slide down there. What is the best way to fix this? Should I remove the mirror and hang it again or try to lever it back into place and somehow get the vanity against the wall again?Read More
