Mirror Clips - Mounting the Top Clips???
Old 10-12-23, 02:13 PM
I
Received 1 Upvote on 1 Post
Folks,
I’ve bought these clips to hang my mirrors with. The retaining screws are hidden from view once the mirror is in position. So….fixing the top clips…any tips on making sure I get the screw mounting hole in the correct position? Too high and it will either look crap or may not even latch on the mirror. Too low and the mirror may not seat. Apart from timely and accurate measurement are there any other approaches anyone has used? These are the clips. Fitting the bottoms will be straightforward, I have a spirit level to get them in line correctly, it’s the tops I don’t want to mess up.
C.R. Laurence MC00BN CRL Brushed Nickel 5/8" Wide Beveled Mirror Clip Set
Top Answer
10-12-23, 03:26 PM
2john02458
2john02458 is offline
Received 387 Upvotes on 337 Posts
Install the bottom clips.
Remove the top piece of an upper clip.
Set the mirror in place on the bottom clips.
Place the main part of the upper clip on the top of the mirror.
Mark a line across the upper clip.
Remove the mirror.
Hold an upper clip against the line and covering it (or ~ 1/16 inch above for clearance, mark for the screw and install the upper clip.
insert the mirror and install the top pieces of the upper clips.
Old 10-12-23, 03:26 PM
2
Remove the mirror.
iceflow, XSleeper voted this post useful.
Old 10-13-23, 07:36 AM
I
Yep, thank you. I actually thought of this as well last night.....honest! I don't know what I was thinking making the post. Anyway many thanks for the response and the precise step by step instructions. Much appreciated.
