Waterproof window structure for greenhouse
Old 04-16-16, 08:29 AM
V
Lightbulb Waterproof window structure for greenhouse
Hi all !
I want to make an automatic window for a greenhouse. The window will be triangular and it should be implement in the structure of the greenhouse. My greenhouse has round bars with a diameter of 34 mm.
Does anyone has an idea of what is the best way to design and make the window, so my greenhouse will be waterproofed when the window is closed ?
I thank you in advance!
With regards,
Arne Speckstadt
Old 04-16-16, 03:38 PM
Received 77 Votes on 72 Posts
Going to need some pictures for this one.
Why does it need to be a triangle?
I've never seen an opening sky light that shape or one that can be attached to round supports.
Since this is mainly a US based web site I'm guessing that's not where you are since your using metric measurements.
There's no local green house company's that can help you out with this?
Old 04-17-16, 02:25 PM
W
Received 19 Votes on 18 Posts
Frame
Is this the framework and is your greenhouse in the shape of a half cylinder?
What does this mean?
