Making new doors for a trash can shred
Old 04-28-17, 05:02 AM
B
Hi.
We have an old 'trash can shred' or whatever you call it on the side of the driveway that was custom built by a previous owner and is beginning to get flimsy and such. It's got a door that you open on the front to get to the trash, but it's only on one half of the shed and so putting trash into the other can is kind of a pain.
Anyways, I have an idea to make 2 doors maybe 3/4 or whatever so that I can just load trash into the plastic trash bins without having to open the door every time and then use the doors when it's time to bring the bin to the curbside on trash day.
What is the standard planks that I can use to make the door? I'm thinking of using planks of some type of wood and then some 2x4's for the 'frame' connected with some of those metal things that secure the wood together.
Sorry for my technical ignorance, I don't know what the standard terms for all those parts are. Are the 2x4's called stiles maybe?
Old 04-28-17, 05:06 AM
B
Actually maybe the trim is 1x4 wood and then it says to use 5/8 inch wood for door planks?
Old 04-28-17, 05:25 AM
Received 759 Upvotes on 664 Posts
A pic or two of what you have would give us a better idea of what should be done.
Old 04-28-17, 05:35 AM
Consider using an exterior grade plywood for the doors. You can paint or stain the plywood. Depending on the door sizes and framing you could go as thin as 1/2" plywood to keep the weight low. Can you post a picture of what the shed looks like now?
Old 04-28-17, 09:37 AM
B
I can when I get home thanks
Old 04-29-17, 06:28 AM
W
Received 60 Upvotes on 52 Posts
Terminology
Vertical door frame members are called "stiles" and horizontal door frame members are called "rails".
If you use lap joints at the corners of the frame, no right angle brackets will be needed.
Old 05-07-17, 08:46 AM
B
Here's some pics. What should I do to upgrade, fix, etc?
Old 05-07-17, 09:50 AM
Replacing all the rotten/decayed wood would be a good start.
