Hinge help
Old 03-29-17, 09:31 AM
D
Hinge help
Hi all,
I'm new to this forum. I just need to know about cylinder hinges. I tried on local shops but no luck. I found online but It doesn't fit my needs. It's too small. I don't care about the material but not plastic. Diameter of the hinge should be around 10mm or 15mm(max)
Please help me. Give me Amazon or ebay link to buy.
Thank you all
[ATTACH=CONFIG]78914[/ATTACH]
Old 03-29-17, 10:17 AM
Shadeladie's Avatar
Super Moderator
Received 398 Upvotes on 326 Posts
Where are you located? You appear to be from another country. This is a US based message board, so no one may be able to help.
Old 03-29-17, 10:33 AM
D
Yes. I'm outside from US. I appreciate if you can help me with buy online.
Old 03-29-17, 10:53 AM
C
Received 174 Upvotes on 142 Posts
Here in US they are called barrel hinges. A search for that will get you many choices and online sources.
