What type of hinge do I need?
Old 05-20-17, 10:17 AM
_
I'm building a display case with a 3 sided front view (like a half hexagon shape) and the center frame will be the door to get inside. My problem is I don't know what type of hinge to use...? I want the hinges to be hidden. The other problem is the edges that would hold the hinges are cut at a 30 degree angle.
The second picture shows the joint where the hinges would need to be. There will also be a top and bottom plate to enclose it all. So if there is a type of hinge that could be attached to those plates that's an option too. I just need them to be hidden and out of sight from the outside
Old 05-20-17, 10:51 AM
W
Received 19 Votes on 18 Posts
Hinges
Small butt hinges or a piano hinge should work.
Old 05-20-17, 11:00 AM
Received 1,113 Votes on 1,033 Posts
Old 05-20-17, 11:42 AM
_
Those types of hinges would be visible front the outside right?
Old 05-20-17, 11:56 AM
C
Received 2 Votes on 2 Posts
Look at Soss Invisible hinges. They will do what you want. Bit of a bear to mount though. Barrel hinges would also work; they are not as strong but are easier to mount.
With either you will have to verify that you have enough thickness for the required bore/mortise, since it will be at an angle because of your angled edges.
Old 05-20-17, 01:05 PM
_
Yea I seen both of those types of hinges and thought the same about the amount of mounting material. What do you think about those knife hinges?? Would those work for this?
Old 05-20-17, 01:42 PM
Handyone's Avatar
I haven't used knife hinges but it looks like they will work. You would use a router and guide to mortise the top and bottom of the door and the face frame.
You can test the pivot point location with some scrap wood.
I think Carbide's reply is best though, SOSS or barrel.
Old 05-20-17, 01:59 PM
C
Knife hinges would work, but a small amount of the pivot will be visible from the front.
Old 05-20-17, 02:27 PM
_
Ok I will check all those options out
