Metal Strong’s door
Metal Strong’s door
The screws that hold my storm door glass in are stripped how do I replace them
Strong? Is that the brand name? On some doors those screw clip inserts might be replaceable. Can you upload a picture of one of the screw and fixture? As a temporary fix you can try using a toothpick inserted into the hole and then tighten the thumb screw. If it catches only at the beginning, you can put a folded piece of cardboard to span the gap.
