Removing Craftsman tool chest drawer
Old 04-04-23, 06:17 PM
R
Red face Removing Craftsman tool chest drawer
Need to remove a drawer from a craftsman 5 drawer tool chest. Can't find old op manual. Tips? Links?
Thanks much, ronnie
Old 04-04-23, 06:45 PM
P
Received 1,954 Upvotes on 1,750 Posts
There are different types of latches so you need to look for yours. Pull the drawer all the way out and look at the slides. You might see a metal tab you need to push in or pull out slightly. If the latch doesn't release close the drawer slightly to release tension on the latch and try again.
Old 04-04-23, 10:57 PM
Received 3,632 Upvotes on 3,254 Posts
I have two Craftsman five drawer boxes. They're different but the drawers come out the same way.
Push that metal clip in on both sides and drawer will slide out.
Much easier to do with an empty drawer.
Craftsman
Old 04-05-23, 07:05 AM
2
Received 361 Upvotes on 312 Posts
Drawer slide release:
Sometimes it is metal, sometimes it is plastic. Sometimes it pushes up, sometimes it pushes in.
