Is there such thing as an open eye bolt that's also shouldered?
Old 06-21-23, 11:48 AM
Received 4 Upvotes on 4 Posts
I'm trying to accomplish three things with this fastener:
1) have a predictable height (hence the shouldering)
2) allow a chain link to enter (hence the open part)
3) not have to use additional quick-links that take up space (otherwise I could use a closed eye bolt)
I looked online and an eye bolt is either shouldered or open but not both. Any other type of fastener come to mind that's not a screw but a bolt system?
TIA
Old 06-21-23, 12:04 PM
Norm201's Avatar
Received 716 Upvotes on 637 Posts
Did you check McMaster -Carr.
If you can't find an open shoulder bolt use a fully threaded shoulder bolt and cut out a section of the ring to make it open.
edit: As long as it won't be used for lifting or have ant tension this be OK
Old 06-21-23, 12:09 PM
Norm201's Avatar
You can also use a fully threaded open eyebolt and run a nut to the top and use that as your shoulder.
cwbuff voted this post useful.
Old 06-21-23, 12:12 PM
I checked McMaster-Carr, I order from them from time to time. They don't have it.
Cutting may be the only option.
I've tried using a nut as the shoulder but within the same dimensioned bolt there is variation on how high the nut will go up so if I have several of them in a row they will not be perfectly even
Old 06-21-23, 12:42 PM
Norm201's Avatar
Not surprised if they were imported (China or Mexico). You need to get US made and be sure full threads are cut to the same height.
Old 06-21-23, 08:50 PM
Z
Received 416 Upvotes on 369 Posts
I've never seen a shouldered open bolt, since most shouldered eye bolts are designed that way for strength. And an open side defeats the purpose.
Similar to shouldering the nut, you could use a nyloc nut as the shoulder and use a ruler or calipers to adjust it for each eye to be perfectly matched. Maybe a bit more work, but I don't see why you couldn't get it easily within 1/16" or 1/32" accuracy that way.
Old 06-22-23, 05:37 PM
If I can't have a shoulder then I might as well use an L-Shaped bolt.
I would confirm first that the USA-made ones have exact threading.
I want my product to be made in USA and if I use foreign components then it's not really (I think)
