Dirty sock syndrome
Dirty sock syndrome
It seems I have the dreaded DSS ( Dirty Sock Syndrome ); again, this is the second coil that has went bad ( coated coils ) to mention as well. So allow me to try explain how how this all played out.
I opened a thread back in '13 w/ a odor issue well it came to be a DSS so the contractor came out & changed the coil w/ a coated one.
So that resolved the issue for good while through heating season of '13 & then the smell came back very lightly in '14 so the guys came out & put some ClenAir in the unit that helped it for the rest of the heating season of '14.
Now '15 heating season came & the smell returned, so the HVAC guy came out & done another investigation & found the smell had gotten worse & I could tell it stunk badly. So they opted to change the coil again ( Coated ); & that cleared it up & fixed the issue all together.
Now we are into the '16 heating season & here we go again DSS again badly. So now its been less then a year since the new coil has been installed & same issue.
I honestly think they need to just replace the whole air handler & see if that resolves the issue, What do you think?
So now I will be calling the HVac guys again - I got a 10year replacement on coils from air handle to outdoor unit. But this is getting crazy changing coils yearly?
What can I do to talk to the Hvac guy or Trane to get the unit itself replaced they have attempted & attempted & all times has failed.
So any suggestions & comments that I need to move forward w/ monday morning?
Heat Pump Info Below :
2/Ton Trane Condenser ( Model : 4TWB3018-060 )
2/ton Air Handler ( Module : 4FWCA, 4FWCF )
Honeywell Non-Programmable FocusPro TH5000 Series
I will be calling my HVAC techs tomorrow but I am just wanting to reach out to see if anyone else has experience such problem, & if so what was your resolution.
My theory is they need to just remove that full air handler & do a full replacement. Possibly the whole unit is compromised?
DSS is caused by the environment the coil is in. But in the end its still the manufactures issue. How about a aluminum coil. Maybe treat what you have with BBJ and First strike.
The HVAC contractor came out today & did a diagnosis & affirmed I do indeed have the DSS issue again. So now this is the second 'coated coil' that has been effected by this DSS problem. & the coils are aluminum w/ a updated coating that suppose to prevent this DSS problem.
So its back to the drawing board & possibly get another coil installed in the air handler. The unit is located in the attic of my house.
joshua is not monitoring this thread.
You would stand a better chance of him responding by sending him a PM.
Click on his name, then on private message and send him a message.
A heat pump related problem.
The aluminum coil reacts with with the humidity and something that is in the air. It cause a mold and slime buildup on the coil and in the condensate pan. The coil gives off a rotten smell. The coils can be coated to reduce the smell. Sometimes the coatings work and sometimes it's only temporary.
This guy says cleaning with PineSol helped him. you tube/watch/pine sol
Proper orientation of the A-coil relative to airflow
I have what is a simple question I hope. For a horizontally installed heat pump system what is the proper orientation of the A-coil ( return
My new system is a 2, and I am wondering if this could have something to do with DSS. Maybe the coil is drying differently between cycles.
Thanks for any input.
Has anyone attempted an air quality test to see if there is something in the air that is causing the problem?
No, how would I go about this? Do the larger HVAC firms offer this service? I called the American Lung Association and asked for some names but they have no recommendations for central VA.
But, still have the question about A-coil orientation (see below). Any help?
Not sure about coil orinatetion,but I would go with the mfg. recommendations, also I just came across this site while looking for some filters,I wonder if any of these carbon activated filters would work for you,I can't copy the link but the mfg. is D-Mark,Inc. just Google it.
Air quality testing To learn more about our Indoor Air Quality Services including mold testing and mold inspections, contact us in Charlottesville at 434-962-8721 or 434-977-1409.
Good luck
Geo
Good luck
Geo
